QCAD auf Webserver
Moderators: andrew, Husky
BastelFritz
Re: QCAD auf Webserver
Post by BastelFritz » Tue Apr 21, 2020 8:06 pm
user@server ~/opt/qcad-3.24.3-trial-linux-qt5.13-x86_64 # ./qcad -platform minimal -h
QCAD version  3.24.3
Warning:  QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-web64'
Warning:  This plugin does not support application fonts
Warning:  RPropertyTypeId::generateId: property already initialized:  7RObject : "" : "Invisible"
./qcad: line 9: 31311 Segmentation fault      LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
Interessanterweise kommt bei dieser Version heute nicht die Meldung "Fontconfig error: Cannot load default config file", die am 17.4. kam, weiter oben sieht man es ja noch. Bei fc-list kommt die Meldung aber auch heute.
Das Verzeichnis wird erstellt und ist leer: '/tmp/runtime-web64' => Schreibrechte da sind also vorhanden.
Ich habe noch mal die Befehle mit gdb ausgeführt:
Schritt 1:
user@server ~/opt/qcad-3.24.3-trial-linux-qt5.13-x86_64 # LD_LIBRARY_PATH=. gdb --args ./qcad-bin -platform minimal -h
GNU gdb (Debian 7.12-6) 7.12.0.20161007-git
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./qcad-bin...(no debugging symbols found)...done.
Schritt 2:
(gdb) run
Starting program: /home/opt/qcad-3.24.3-trial-linux-qt5.13-x86_64/qcad-bin -platform minimal -h
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
QCAD version  3.24.3
[New Thread 0x7fffe544d700 (LWP 1137)]
warning: unable to open /proc file '/proc/1120/status'
[New Thread 0x7fffe4c4c700 (LWP 1138)]
[Thread 0x7fffe544d700 (LWP 1137) exited]
[Thread 0x7fffe4c4c700 (LWP 1138) exited]
[New Thread 0x7fffe4c4c700 (LWP 1139)]
Thread 1 received signal SIGSEGV, Segmentation fault.
0x00007ffff2865218 in QTJSC::ExecutablePool::systemAlloc(unsigned long) ()
   from /home/opt/qcad-3.24.3-trial-linux-qt5.13-x86_64/./libQt5Script.so.5
Schritt 3:
(gdb) bt
#0  0x00007ffff2865218 in QTJSC::ExecutablePool::systemAlloc(unsigned long) ()
#1  0x00007ffff28ed630 in QTJSC::JSGlobalData::JSGlobalData(bool) ()
#2  0x00007ffff28edac8 in QTJSC::JSGlobalData::create() ()
#3  0x00007ffff298ff66 in QScriptEnginePrivate::QScriptEnginePrivate() ()
#4  0x00007ffff299086e in QScriptEngine::QScriptEngine() ()
#5  0x00007ffff6b271db in RScriptHandlerEcma::RScriptHandlerEcma() ()
   from ./libqcadecmaapi.so
#6  0x00007ffff6b2b45b in RScriptHandlerEcma::factory() ()
#7  0x00007ffff5ff6216 in RScriptHandlerRegistry::createScriptHandler(QString const&) () from ./libqcadcore.so
#8  0x00007ffff5ff6443 in RScriptHandlerRegistry::getGlobalScriptHandler(QString const&) () from ./libqcadcore.so
#9  0x00000000004048dd in ?? ()
#10 0x00007ffff4cb02e1 in __libc_start_main (main=0x4040f0, argc=4,
    argv=0x7fffffffe608, init=<optimized out>, fini=<optimized out>,
    rtld_fini=<optimized out>, stack_end=0x7fffffffe5f8)
    at ../csu/libc-start.c:291
---Type <return> to continue, or q <return> to quit---
#11 0x0000000000404d79 in ?? ()
Post by andrew » Tue Apr 21, 2020 8:44 pm
Die Speicherreservierung geht hier wohl schief.
Kannst du mal den Speicherverbrauch des Servers beobachten während QCAD startet (z.B. mit top in separater Shell)? Kann sein, dass der Server am Limit läuft.
BastelFritz
Post by BastelFritz » Tue Apr 21, 2020 9:02 pm
Alles verrammelt:
user@server ~ # top
Error, do this: mount -t proc proc /proc
user@server ~ #  mount -t proc proc /proc
mount: only root can use "--types" option
user@server ~ # cat /proc/meminfo
cat: /proc/meminfo: No such file or directory
user@server ~ # free
Error: /proc must be mounted
  To mount /proc at boot you need an /etc/fstab line like:
      proc   /proc   proc    defaults
  In the meantime, run "mount proc /proc -t proc"
user@server ~ # cat /etc/fstab
cat: /etc/fstab: No such file or directory
