it's been a while that I've been using the program. I probably need to do upgrades and have not. I cant seem to locate my instructions either. I'm having a problem printing and need to go over the instructions. How do I contact somebody to help me with these issues? I might need to do a new download.
the program is great and I enjoy using it, I just need to catch up again.
thanks Wayne Evans Houston TX
help , I havent been on here for some years now.
Re: help , I havent been on here for some years now.
Hi Wayne - welcome back to the QCAD forum,
Indeed - sounds like you should update your QCAD version. I assume you bought your version more than 1 year ago what means you don't qualify anymore for free updates.If I'm right then you need to purchase a new license to get the most current QCAD version. Tip: If you own a license for LESS than 3 years there is a good chance to qualify for a rebate. In that case please contact direct via e-mail Andreas Mustun / RibbonSoft GmbH and he will tell you what he can do for you. The address is: [email protected]
After you sorted this out and the current version is installed on your system we can talk about to get you back on track with your drawing needs. Ok?
