Show buttons in version 3.27.8.0
Post by CVH » Sun Oct 09, 2022 9:00 am
Andrew,
I installed .8 beside .6 so I can still work with the prior installed version.
I have 'Always show all properties' set for the Property Editor.
In version .8 I am confronted with more 'Show' buttons.
e.g.:
- the 'Total Area' for a single circle.
- or the 'Total Length' & 'Area' & 'Total Area' for a single polyline.
It doesn't matter if I turn on 'Always show all properties' or not.
Figuring that this preferences has no influence on showOnRequest that was changed for single (slow) Hatched area.
Figuring that a single entity selection does not turn on/off summed 'Total' properties.
How can I avoid 'Show' buttons in later versions than 3.27.6.0?
Return to “Chat”
