Z axis height
Z axis height
how is this height set? Where does it come from?
Re: Z axis height
This forum is generally related to QCAD / CAM matters. Moreover, you need to be more precise in your question.
However, when CAM program is started, the position of the Z axis is controlled by a g-code. In the Candle software, you can initially move the spindle manually using the arrow buttons on the right side of the window.
Konrad
Konrad
