Question about ongoing port to qt 6
Post by CVH » Tue Sep 13, 2022 6:48 pm
Andrew,
I do follow the changes made in the GitHub repository.
Noticed the ongoing port to qt 6.
My concern is about the changes made to .js script files, others I won't address in direct.
Recent examples of some changes in special:
-   var buttons = new QMessageBox.StandardButtons(QMessageBox.Yes, QMessageBox.No, QMessageBox.Cancel);
+   var buttons = makeQMessageBoxStandardButtons(QMessageBox.Yes, QMessageBox.No, QMessageBox.Cancel);
-   fileDialog.destroy();
+   destr(fileDialog);
Among others but I need to verify these one by one as I din't keep track of what I copied over.
Or will there be a list of changes?
Should we adapt user created scripts the same way?
In special those scripts that became part of the of the QCAD distribution.
Timeframe? Only when Qt 6 is included or globally?
Re: Question about ongoing port to qt 6
Post by andrew » Tue Sep 13, 2022 7:44 pm
It's too early to make any changes. This is all preliminary and might still change / revert.
Qt 6 has no (decent) JavaScript environment, so we have to implement a lot from scratch. This will still take at least some months.
Return to “Chat”
