[solved] QCAD Professional commands
dhe1960
Post by dhe1960 » Tue Sep 13, 2022 2:58 am
I recently purchased QCAD Professional after using QCAD Tutorial.
The MOVE / COPY and several other commands remain unavailable in command drop down boxes.
Can you provide a remedy for this issue.
Thanks,
dhe1960
Re: QCAD Professional commands
Post by CVH » Tue Sep 13, 2022 5:01 am
Hi, and welcome to the Forum.
Several methods require an existing selection upfront.
The sequence is then:
'these entities' .. Move/Copy (MV) ..
or 'this arc' .. Rotate (RO) ..
Other methods ask to select the entities in question, see status bar.
Trim (RM) .. Limiting entity .. Entity to trim ..
Post by andrew » Tue Sep 13, 2022 7:10 am
dhe1960: Please refer also to the user manual which indicates the steps required to use these tools: Help > Reference Manual or online at:
https://qcad.org/doc/qcad/latest/refere ... /Translate
dhe1960
Post by dhe1960 » Tue Sep 13, 2022 1:13 pm
Thanks for the support
Return to “Chat”
