Line Infinite
oldrunnerdude
Line Infinite
Post by oldrunnerdude » Thu Aug 04, 2022 4:05 am
Using point to point line, always draws to infinite.
Even with the latest updates
3.27.6.0 (3.27.6)
Windows 10
Re: Line Infinite
Post by Husky » Thu Aug 04, 2022 5:03 am
Launching the "Line from 2 Points" tool triggers like other tools to show an Option bar above the drawing area. The line modes are: Line Segment, Infinitive or Ray. In your case you have to use the first option for Line Segment. BTW: This choice will be remembered by QCAD regardless an update.
oldrunnerdude
Re: Line Infinite
Post by oldrunnerdude » Fri Aug 05, 2022 2:16 am
That is it! thanks!
Return to “Chat”
