Windows 10 Pro
version 3.27.5.0
I apologise if i have made any mistakes with the forum protocol, i'm new at this.
My supplier has a CAD portal and when i try to open the file in QCAD it is incorrect.
Thank you
CAD drawing not showing correctly
- Registered Member
- Internorm_KF410_CAD.dwg
- (225.71 KiB) Downloaded 213 times
- Correct CAD image.JPG (50.29 KiB) Viewed 3034 times
- qcad incorrect.png (22.71 KiB) Viewed 3034 times
Re: CAD drawing not showing correctly
Hallo,
Be careful, the plans are the property of Internorm and should not be published.
Please elaborate "incorrect"! What for we have to look at??? What I notice so far is that your "Incorrect" screenshot doesn't match the dwg drawing at all.DarranRound wrote: ↑Thu May 12, 2022 2:01 pmMy supplier has a CAD portal and when i try to open the file in QCAD it is incorrect.
Same problem with the "Correct" screenshot ...
