[solved] Area
[solved] Area
How do you change 6.2424e+6 to square feet in an polygon area calculation? I have not been able to find an answer to get square feet for area total. Thanks
Re: Area
You can change the Label Format below:
Menu/Edit/Drawing Preferences/Dimension Settings/Label Format
