Grabbing information from a DWG drawing
rona
Post by rona » Fri Dec 03, 2021 3:22 am
How do I grab part of a DWG drawing and import that into QCAD? Is there a cut and paste feature that I'm missing?
Garage Elevation.pptx
Import this puppy so I can delete what I don't need
(586.49 KiB) Downloaded 235 times
Re: Grabbing information from a DWG drawing
Post by CVH » Fri Dec 03, 2021 5:26 am
When the document in question is indeed a DWG file one can simply copy a selection to another drawing.
Displayed entities may still reside on layers that are locked, see Layer List.
Before one can select such entities, their layers need to be unlocked.
With a selection it should be a plain copy/paste. :wink:
Return to “Chat”
