Bought the paid version, how to delete the trial?
Crouder
Post by Crouder » Mon Jun 14, 2021 1:13 am
We bought the professional version, how do i get the trial version off? So i can use the full version.
Re: Bought the paid version, how to delete the trial?
Post by Husky » Mon Jun 14, 2021 1:20 am
On which OS?
Post by andrew » Mon Jun 14, 2021 5:33 am
Accessing your Downloads
An e-mail was sent to you directly after purchase with a link to your download area where you can download the full version of the software and the e-book if applicable. The link is valid until one year after purchase. The e-mail also states until when the link stays valid.
No key or activation of any kind is required. The download link can also be used to download the software / e-book again and to download updates until one year after your purchase.
If you cannot find this e-mail, please look also in your Spam or Bulk mail folder.
The e-mail subject is "Order / Commande / Bestellung" + your order number. Please keep in mind that you might have used a different e-mail account when placing your order.
You can request your download link again through our website at:
https://qcad.org/recover-lost-download-link
Note that you might have used a different e-mail address for your purchase.
Do not download the free QCAD packages from our public web site as these are trial versions that cannot be turned into full versions.
Previously Installed Trial Version
If you have previously installed a trial version, you may want to uninstall that first as this is no longer needed.
- Under Windows, you can simply install the full version over the trial version using the downloaded MSI installer.
- Under macOS, drag "QCAD.app" in Applications to the Trash to remove the trial version. The full version is called "QCAD-Pro.app"
- Under Linux, trial and full versions are installed into separate directories. Simply delete the directory of the trial version in the opt folder of your home directory.
Running the Full Version of QCAD Professional
Please make sure that after downloading the full version, you also install the full version (not a previously downloaded trial version that still happens to be in your download folder). Please make sure that after installing the full version, you also run the full version (not a previously downloaded and installed trial version). If in doubt, uninstall all versions of QCAD and install the full version from scratch.
Return to “Chat”
