[solved] Library Parts - Incorrect size
DaveArt1957
Post by DaveArt1957 » Wed Apr 14, 2021 1:35 pm
Hi, I'm trying to insert library parts into a drawing in Model Space but the parts come in at the wrong size. For example, I'm trying to add the "People Group" from the Architecture/People Folder into a 1:1 drawing, but they end up only 6.3mm tall!! On the ribbon at the top, the Scale is set to 1:1, when doing the insert. What is going wrong?
Re: Library Parts - Incorrect size
Post by Husky » Wed Apr 14, 2021 7:02 pm
The unit for "people_group_silhouettes.dxf" is "none".
QCAD will convert an inserting drawing to the actual used drawing unit. In this case none to mm.
Size of a person in "people_group_silhouettes.dxf" is around 6 (unit none).
If you insert that in a drawing, which uses mm, then the scale factor has to be something around 300. (6 none x 300 = 1800 mm)
DaveArt1957
Post by DaveArt1957 » Thu Apr 15, 2021 9:30 am
Thanks Husky. I see - that works.
(Thought the size of the items in the library would be of the correct size in the first place.)
Cheers
Dave
Return to “Chat”
