[solved] Line style on an arc only wants to go one direction
Markz
Post by Markz » Tue Feb 02, 2021 5:04 am
When I tried drawing a drainage linestyle on an arc, it wants to go the wrong way. It wants to go this way whether I reverse the points, redraw it with the arc tool, make it with the parallel tool, mirror it, flip it, and even if I use the OTHER drainage linestyle that runs the opposite direction. I can force it by drawing a spline along some points placed on an arc. But I'm wondering why I can't just get it to work in the first place.
Thanks!
Linux, Qcad 3.25.2
qcad-plumbing.dxf
(104.2 KiB) Downloaded 385 times
Re: Line style on an arc only wants to go one direction
Post by Husky » Tue Feb 02, 2021 5:55 am
Yes, I can confirm that for your version (3.25.2). It is fixed with the QCAD Snap Version: 3.25.2.9 what means it is part of the next stable QCAD release.
Select Arc / Reverse (RV) ...
Markz
Post by Markz » Tue Feb 02, 2021 3:52 pm
Thanks for the info!
Return to “Chat”
