I'm trying out QCAD. I've hit a snag. Whenever I try to apply a hatch to the pentagon in the center of the drawing, it says "Loop not closed at ..." where ... is the location where two corners of the pentagon meet. I've zoomed in on the point as closely as possible, and they meet. I've tried to edit the two lines by extending them and then trimming them. I've tried moving the whole pentagon to a separate layer and only showing that layer. I've tried converting the pentagon into a polyline object. Nothing works.
Yes, I could just recreate the pentagon, but I would like to know what I'm doing wrong, and why I can't seem to fix it. I've put a small red circle around the point in question to explain what I'm seeing.
Thank you!
Mark
[solved] Loop not closed at point ...
- test-project.dxf
- (136.43 KiB) Downloaded 350 times
Re: Loop not closed at point ...
your pentagon persist out of a lot of duplicates (entity on entity). Remove them with "Detect Duplicates" (MD), default tolerance 0.001, try to hatch again.
Keep us posted.
Keep us posted.
Re: [solved] Loop not closed at point ...
Thanks for the help! All I had to do was delete a single line and it was good. And now I know about the dangers of duplicates.
