Is there a way to toggle between english and metric in QCad?
I'm currently stuck in inches and no matter what I set the drawing units to in Edit->General->Drawing_Unit it stays in inches.
I've looked at the documentation and searched around the forum and I seem to be doing what I should be doing...
What am I missing???
[solved] Switch between metric & english?
Re: Switch between metric & english?
To change the unit for the whole drawing please use the converting tool in QCAD. Menu / Edit / Convert Drawing Unit. It will convert the whole drawing inclusive the proper scaling regarding the change.
Yes.
That will simply explained only change the name of the unit. e.g. a 100 inch line is then 100 mm.
Awesome, thanks!
