Is it possible to have a screen separated in two views, where the first is a plan drawing and in the second the isometric drawing, where I create piping lines in the isometric, the same appears on the first screen, in the plan drawing?
Regards
(solved) Separated views
- Active Member
Re: Separated views
Yes.Roberto Vid wrote: ↑Fri Oct 09, 2020 12:59 pmIs it possible to have a screen separated in two views, where the first is a plan drawing and in the second the isometric drawing, ...
No. A plan drawing will not update an isometric drawing or vice versa.Roberto Vid wrote: ↑Fri Oct 09, 2020 12:59 pm... where I create piping lines in the isometric, the same appears on the first screen, in the plan drawing?
- Active Member
Re: Separated views
Many thanks for the awnser.
Regards
Regards
