Question: I just watched a neat video on the perimeter length of an ellipse. What formula/approximation does QCAD use?
Best
[Answered] Perimeter of an ellipse
QCAD 3.26.0 / Windows 10 2004 x86_64
Re: Perimeter of and ellipse
Ellipse are indeed the tougher ones among the entities.
There aren't closed form solutions.
Talking about perimeter length, what about the others properties ...
Intersections ... Point on ...
Well, I would not know.
Andrew can tell you that.
So, I keep lurking.
So, I keep lurking.
QCAD uses Simpson's Rule as approximation for ellipse arc lengths.
Thankx
Re: [Answered] Perimeter of an ellipse
Yes, thanks Andrew. Number of iterations? Or is that dependent on particular setup/specifics of the drawing (such as ellipse ratio)? (I think if I tried to read the code, it'd be like looking for a needle in a haystack
I am just curious as I had just watched an entertaining video on the subject.
Best regards
Hugh
Best regards
Hugh
