Hidden lines
David R. Machin
Hidden lines
Post by David R. Machin » Sat Aug 08, 2020 5:14 pm
when I use this command, the resulting line is not dotted lines, but continuous, even though I have selected dotted lines. What must I do to correct this?
I should say that I am doing small scale engineering drawings for model engineering.
Re: Hidden lines
Post by CVH » Sat Aug 08, 2020 6:30 pm
hi, what command do you mean?
Return to “Chat”
