1. What is the computer system requirements to run Qcad?
2. What size files can Qcad handle?
Thanks in advance for your response.
Larry
Computer requirements
Re: Computer requirements
https://qcad.org/en/faqlarry.hill wrote: ↑Sat May 16, 2020 12:24 am1. What is the computer system requirements to run Qcad?
Note: That is minimum - everything "faster" will help you at your daily task ...
Depends partly on your hardware. I run a standard Win10 computer but with a higher RAM size (16 GB). Nevertheless I try to avoid file sizes over 10 MB ...
Just to be sure I recommend to use the trial offer for a solid evaluation. It' free of charge ...
https://www.qcad.org/en/qcad-downloads-trial
