Nesting Issues
Nesting Issues
Im having the following issues when nesting
1) Holes are not nested together with the part
2) Lines are being nested separately even when it comes from the same part
3) Is it possible for the nesting to fill up the first sheet of the material before using the second sheet?
4) Sometimes, overlapping occurs when I use 8 rotation.
Im wondering if there are any solutions to the issues above?
- Lines split up.PNG (9.93 KiB) Viewed 8301 times
- Holes not nested.PNG (11.08 KiB) Viewed 8301 times
Re: Nesting Issues
Most likely that part hasn't a closed contour. If so, please close the contour and try again.
If the nesting still fails please attache the dxf/dwg drawing and indicate Operating system and QCAD version.
Just like our Forum rules are asking for ...
- Newbie Member
Re: Nesting Issues
I'm looking to do nesting, but without rotating parts.
There is the rotation option but I can't set 0 for no rotation.
Qcad Cam 3.24.3 on Ubuntu
Re: Nesting Issues
If you set the rotation to 4 then it means that each part can be rotated 0 degrees, 90 degrees, 180 degrees or 270 degrees,freeman974 wrote: ↑Fri Jul 03, 2020 10:13 pm...
Set it to 1 and there will not be a rotation ...
- Newbie Member
Re: Nesting Issues
I've already tried it with one, but it's still giving me rotations.
Re: Nesting Issues
It works flawless with my QCAD/CAM version ....
If possible please attache the drawing for further investigation. Thanks.
- Newbie Member
Re: Nesting Issues
The attached dxf file, thank you
- test.dxf
- test file
- (158.36 KiB) Downloaded 402 times
Re: Nesting Issues
Thanks.
Yep - you are right. i wasn't able either to find a setting without a rotation.
Maybe Andrew has more info on that behavior ...
Re: Nesting Issues
Please make sure that aligning to the longest side is disabled:
Edit > Application Preferences > CAM > Nesting > Align part angles to axis
If the problem persists, please indicate your QCAD/CAM version and platform.
Re: Nesting Issues
That did the trick with my version 3.24.3.0. Thanks!
- Newbie Member
Re: Nesting Issues
It's working fine, thank you very much.
What is the difference between a value a 1 or a 20 of the "Hul resolution for blocks" option?
