Nesting Issues
Wkiamin
Nesting Issues
Post by Wkiamin » Mon May 04, 2020 5:51 am
Im having the following issues when nesting
1) Holes are not nested together with the part
2) Lines are being nested separately even when it comes from the same part
3) Is it possible for the nesting to fill up the first sheet of the material before using the second sheet?
4) Sometimes, overlapping occurs when I use 8 rotation.
Im wondering if there are any solutions to the issues above?
Lines split up.PNG (9.93 KiB) Viewed 1542 times
Holes not nested.PNG (11.08 KiB) Viewed 1542 times
Re: Nesting Issues
Post by Husky » Mon May 04, 2020 7:00 am
Most likely that part hasn't a closed contour. If so, please close the contour and try again.
If the nesting still fails please attache the dxf/dwg drawing and indicate Operating system and QCAD version.
Just like our Forum rules are asking for ... :wink:
freeman974
Re: Nesting Issues
Post by freeman974 » Fri Jul 03, 2020 10:13 pm
I'm looking to do nesting, but without rotating parts.
There is the rotation option but I can't set 0 for no rotation.
Qcad Cam 3.24.3 on Ubuntu
Re: Nesting Issues
Post by Husky » Fri Jul 03, 2020 11:01 pm
If you set the rotation to 4 then it means that each part can be rotated 0 degrees, 90 degrees, 180 degrees or 270 degrees,
Set it to 1 and there will not be a rotation ... :wink:
freeman974
Re: Nesting Issues
Post by freeman974 » Fri Jul 03, 2020 11:18 pm
I've already tried it with one, but it's still giving me rotations.
Re: Nesting Issues
Post by Husky » Fri Jul 03, 2020 11:30 pm
It works flawless with my QCAD/CAM version ....
If possible please attache the drawing for further investigation. Thanks.
freeman974
Re: Nesting Issues
Post by freeman974 » Fri Jul 03, 2020 11:36 pm
The attached dxf file, thank you
test.dxf
test file
(158.36 KiB) Downloaded 71 times
Re: Nesting Issues
Post by Husky » Sat Jul 04, 2020 5:55 am
Thanks.
Yep - you are right. i wasn't able either to find a setting without a rotation. :(
Maybe Andrew has more info on that behavior ...
Re: Nesting Issues
Post by andrew » Wed Jul 08, 2020 9:22 am
Please make sure that aligning to the longest side is disabled:
Edit > Application Preferences > CAM > Nesting > Align part angles to axis
If the problem persists, please indicate your QCAD/CAM version and platform.
Re: Nesting Issues
Post by Husky » Thu Jul 09, 2020 12:01 am
That did the trick with my version 3.24.3.0. Thanks! :wink:
freeman974
Re: Nesting Issues
Post by freeman974 » Sun Jul 12, 2020 11:39 am
It's working fine, thank you very much.
What is the difference between a value a 1 or a 20 of the "Hul resolution for blocks" option?
Return to “Chat”
