Pasting textual Refs to the Command Line
Post by CVH » Thu Feb 20, 2020 11:30 am
I do a lot of my math in Excel.
Created a function to return a textual absolute cartesian reference like:
e.g. "3;5" or "-18,882947;22,469471" in metric.
When I type this text over to the Command Line it is correctly used once after I hit ENTER.
When I copy this cell content and paste it in the Command Line it is used twice as an entry straight away.
The text is indeed terminated by a Winstyle EOL.
A CR and a LF.
The same behaviour counts for only the last of a multiline Copy/Paste.
A: Only columns of cells work (Excel seperates cells in a row with TAB)
B: The double Winstyle EOL is ignored for all but the last entry.
Copying two cells with the texts: "-79;42" and "-32;17"
And pasting as Refs for a new Line would look like this:
Command: line
Coordinate: -79;42
Coordinate: -32;17
Coordinate: -32;17
Next Point: (waiting for a next point)
Meaning that @(-32;17) Qcad created a Null-Line
Texts "-79;42" and "-32;17" are both terminated by CR & LF
Is it possible that Qcad could ignore this last double termination?
Re: Pasting textual Refs to the Command Line
Post by andrew » Mon Feb 24, 2020 11:17 am
Can you try pasting to a text editor first, then copy / paste from there?
Post by CVH » Mon Feb 24, 2020 11:32 am
That was the proofed workaround.
ok thanks,
got it.
Return to “Chat”
