COMMAND
Graham
COMMAND
Post by Graham » Sun Feb 16, 2020 12:36 pm
Hi All
Can anybody please tell me, after drawing a lot of lines etc, what is the quickest way of getting back to the command line. I currently do it by by pressing escape or enter multiple times.
Many thanks
Graham
Re: COMMAND
Post by Husky » Sun Feb 16, 2020 6:37 pm
Have you tried the "Space key" on your keyboard ...?
Graham
Re: COMMAND
Post by Graham » Thu Feb 20, 2020 1:38 pm
Hi Husky
The space key does what it says, moves the cursor to the left/right, does not go back to command,
Graham
Re: COMMAND
Post by CVH » Thu Feb 20, 2020 1:46 pm
My mouse cursor is not moved by pressing the SPACE key.
The cursor inside the Command Line is obviously moved to the right by pressing SPACE key.
Like Husky said:
> Draw / Line from 2 points.
> Drew a bunch of lines.
> Hitted the space key and I am in the Command Line.
Do you have another approach?
Graham
Re: COMMAND
Post by Graham » Thu Feb 20, 2020 2:34 pm
Hi All
Hit the SPACE KEY and the cursor goes to the right.
Hit the ESCAPE KEY several times and eventually got back to command line.
Still no further on.
Graham
Panchdara
Re: COMMAND
Post by Panchdara » Thu Feb 20, 2020 7:26 pm
IF there is a flashing "|" and it moves to the right when you press space bar then you are already in the command line. I remember when I first started with CP/M... I did not immediately comprehend whether I was at command prompt or in the application... was confusing where the application focus was. Then, in a blink it was obvious. But that was then.
QCAD 3.25.2.x / Windows 10 2004 x86_64
Graham
Re: COMMAND
Post by Graham » Fri Feb 21, 2020 11:45 am
Thanks Panchdara
Got it.
Graham
Panchdara
Re: COMMAND
Post by Panchdara » Fri Feb 21, 2020 1:42 pm
Glad to help Graham. Hopefully you'll have fun in QCAD. This forum seems to be the best place to pose your questions and, if history repeats itself, you'll always get the best constructive help/answers. Happy QCAD'n (it's Friday - "NO G")
Return to “Chat”
