Block Hatch anomaly?
Panchdara
Post by Panchdara » Mon Dec 23, 2019 1:24 pm
I can understand Andrews point in viewtopic.php?f=8&t=6831
Whilst making forward progress on a small drawing, I came across a scenario that is similar to that attached.
Same layer each entity
Create open block
close block with line
hatch
fail
Bug or by design?
Cheers
BlockHatch1.wmv
(4.42 MiB) Downloaded 13 times
Win 10, QCAD 3.24.5
TSG
Re: Block Hatch anomaly?
Post by TSG » Mon Dec 23, 2019 2:46 pm
Hatch from segments works well and there is no reason why hatch from selection shouldn't work as well.
So I suggest to write a bug report.
Cheers
TSG
Post by andrew » Mon Dec 23, 2019 4:25 pm
I can confirm that this use case (boundary path elements partially from (different) blocks) is not currently implemented. I'd suggest to duplicate / explode the block for hatching.
Return to “Chat”
