Hatch pattern included in file
Post by CVH » Wed Dec 11, 2019 2:39 pm
This was something included in a post I was preparing.
https://qcad.org/rsforum/viewtopic.php?t=6806
Translated:
andrew wrote:
Wed Dec 11, 2019 10:16 am
(New) Hatches typically use a hatch pattern that was installed with QCAD.
If a DXF / DWG file is loaded, the file may contain a hatch pattern that is not contained in QCAD.
Therefore, hatches along with the pattern(s) used are stored in DXF / DWG.
When a hatch loads and uses such a pattern from the DXF / DWG file,
it will be displayed in the Property Editor by the From Object property (Yes value).
That's easy, confirmed and I can shorten my post. :)
Re: Hatch pattern included in file
Post by CVH » Wed Dec 11, 2019 2:51 pm
Next question:
If we come by a hatch in a file we would like to set apart:
Can we extract such a hatch definition?
Just a thought,
Return to “Chat”
