Hi All
I'm having trouble nesting these parts, could anyone help out here..
Best Regards
John
[SOLVED] Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
- Premier Member
- NestTest-After.dxf
- (208.19 KiB) Downloaded 396 times
- NestTest-Before-NoDims.dxf
- (208.09 KiB) Downloaded 384 times
- After.jpg (124.72 KiB) Viewed 3846 times
- Before.jpg (125.39 KiB) Viewed 3846 times
Re: Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
QCAD/CAM can't identify the proper shape of the largest part. The 20 mm Circle on the very left side needs a bit of trim work ...
After that is fixed a result could look like this one:
- Premier Member
Hi Husky
Oops... Thanks for that...I did these parts when I 1st started using qcad I think I must of trimmed to vertical construction line through centre of arc...
Good pickup..I should of looked at that seeing as it seperated it when nested
Cheers
John
Cheers
John
- Premier Member
Re: [SOLVED] Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
When my year is up I'm definitely going to upgrade to qcadcam just for the nesting feature.. it's brilliant...
