There was an option on the Quick links menu to show only unread posts, but it's no longer there. In fact I had bookmarked that link:
search.php?search_id=unreadposts
It was an easy way to quickly see what's new. Now when I go there, I get "The requested page could not be found." Is there a new place to see all unread posts?
Thanks.
Edit: I just realized this should've gone in the Site Feedback board. Sorry about that.
Has the QCAD forum changed?
Len
QCAD Pro
QCAD Pro
Re: Has the QCAD forum changed?
Yep - same here!
Found an explanation by accident:
andrew wrote: ↑Sat Nov 02, 2019 10:11 pmThere's currently a DDoS attack underway on our server, mostly using the forum search functionality in an attempt to bring the server down by triggering lots of CPU / DB intensive queries. Forum search has been disabled for now until the attack is over. Luckily the rest of our infrastructure can easily cope.
- Premier Member
Probably Autodesk lol... kidding
My apologies. Everything should be back to normal. DDoS attacks are slightly annoying but luckily not much more than that.
Feels like home again.
