Custom Toolbar Icons
John Hyslop
Post by John Hyslop » Sun Nov 03, 2019 3:33 am
Hi All
Using the latest version of Qcad professional here...
is there a way to make your own toolbar with your mostly
used icons on it... eg Line,Arc,Circle,Offset, Rotate... or similar
All opinions will be appreciated :-)
Cheers
John Hyslop
Re: Custom Toolbar Icons
Post by andrew » Mon Nov 04, 2019 8:34 am
You'd have to use the script interface for that (i.e. create a toolbar, add the desired tools to it).
John Hyslop
Post by John Hyslop » Mon Nov 04, 2019 12:44 pm
Hi Andrew
How would I go about that? Could you post an example for one..
Cheers
John
John Hyslop
Post by John Hyslop » Mon Nov 04, 2019 12:45 pm
Hi Andrew
Cheers
John
John Hyslop
Post by John Hyslop » Mon Nov 04, 2019 11:10 pm
Sorry Andrew
Don't know why this posted twice..I posted from my mobile maybe happened that way?
Return to “Chat”
