Quoting and Inserting code on the forum
Post by CVH » Sat Aug 24, 2019 10:11 pm
Before posting a new topic about a contribution it would be nice to properly 'Quote' and 'Insert code'.
My earlier attempts failed and they were all displayed in plain text.
I thought it was my browser or ...
    // This should look as code
    // Terminate without any entity selected
    if (idn == 0) {
        // Push warning to history
        EAction.handleUserWarning("No entities selected!");
        this.terminate();
        return;
CVH wrote:
Sat Aug 24, 2019 7:06 pm
This should be a quote.
There is surely something with Layers being selected and/or being active (edit mode).
This time I had two active Layers
The solution was to NOT set BBCode to disabled.
That was not stated in the BBCode tutorial and afterwards it now seems obvious.
Regards
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Return to “Chat”
