Global Z
Global Z
Post by CVH » Tue Jul 30, 2019 11:04 am
Andrew, All,
First: Could not keep this from the crowd.
Ever seen polylines like this.
It is just a tricky mix of properties. Filed bugreport.
https://qcad.org/bugtracker/index.php?d ... sk_id=1923
Playing with these properties I noticed something odd.
Setting Global Width will also set all segments Widths values.
Changing a segments Widths value set Global Width to empty.
As for 'No' or *VARIES*.
Setting all the segments Widths equal is reflected in Global Width.
And the most common form :
If all Widths are zero the general properties are used.
Just what we expect of it.
But this is not true for Z values.
Setting GlobalZ will set all vertices Z values.
Changing a vertex Z value will not change GlobalZ.
So with a Global Z there can still be local Z's.
Should I file a bug?
And yes, Qcad is 2D native.
I think Global Z = 'No' would be better. Global Width = 'No' too.
And for all having those 3D issues 'No' in flashy RED would be even better.
For that matter I would promote Global Z to a standard property for all types.
Displayed in the General Properties section. in flashy RED.
Sounds as a Feature Request.
Regards
Poly-bulge Global Z & local widths.dxf
Bugreport
(106.56 KiB) Downloaded 167 times
Return to “Chat”
