DWG to SVG
KYKIM
DWG to SVG
Post by KYKIM » Wed Jul 24, 2019 1:37 am
When I called up the DWG file created by AUTOCAD and converted it to SVG, the text was converted.
However, none of the objects can be converted. :cry:
Is this because it's a trial version?
Or is there another way?
Best Regards!
KYKIM
Re: DWG to SVG
Post by KYKIM » Wed Jul 24, 2019 3:07 am
I found the cause. QCAD does not display when the line weight of the layer created by the Autocad is set to default.
Is there any way to change the line weight collectively in QCAD?
Is there any way to change that DEFAULT value?
Re: DWG to SVG
Post by CVH » Tue Jul 30, 2019 3:34 pm
View, Selection filter
Filter on any, Lineweight, =(is), Default
Choose replace selection filter (lefthand icon).
With all Default lineweight selected:
Set common Lineweight in Poperty Editor to desired.
Return to “Chat”
