dimensioning
hiqserv
dimensioning
Post by hiqserv » Tue Jun 04, 2019 6:24 pm
I cant find anywhere to change the number of decimal places for dimensions.
cant find out how to change autosave timing.
cant find out how to change linetype on existing lines. Autocad had a change command that was very usefull
Re: dimensioning
Post by Husky » Tue Jun 04, 2019 6:40 pm
Menu/Edit/Application Preferences/Dimension Settings
Menu/Edit/Application Preferences/File/Autosave
You can do that within the Property Manager (Menu/View/Property Manager) or changing the Layer Attributes.
Return to “Chat”
