Trouble with Bitmap Export Add Extra Margin
jsolerBtis
Post by jsolerBtis » Mon Jan 28, 2019 3:05 pm
Hi!
I'm trying to export my .DXF file to a .TIFF files using QCAD in command line mode, but i don't know how to disable this check: "Add extra margin to compensate for line weight" with command line parameter.
I want to create tiles of this file and i need to create TIFF file with exact precision but this margin is moving my photo.
As example, I'm trying to export this square:
But when I export my TIFF file, we only saw the lower-left corner:
It's possible to call command line QCAD with this check disabled?
Thanks!
Re: Trouble with Bitmap Export Add Extra Margin
Post by andrew » Mon Jan 28, 2019 3:11 pm
Please post the exact parameters you are using for dwg2bmp along with the DXF/DWG file, thanks.
jsolerBtis
Post by jsolerBtis » Tue Jan 29, 2019 9:17 am
Hi Andrew,
I'm calling Qcad with:
-allow-multiple-instances
-no-gui
-autostart
ExportBitmapWorldFile.js (format file that exports TIFF and generates TIFFW too)
-f
-o My output path
-p 0.02
-t "tiff"
In ExportBitmapWorldFile.js i'm just changing properties of:
"width", "height", "resolution" and "margin" (= 0 trying to solve this problem).
(8.85 KiB) Downloaded 102 times
C_M1_P1_0_ARQ.dwg
(496.41 KiB) Downloaded 112 times
Post by andrew » Tue Jan 29, 2019 10:01 am
OK.. perhaps a rounding error? If your lines are 1 pixel wide and you use a margin of 0 the line might just be inside or outside the pixel depending on the values being rounded up or down.
jsolerBtis
Post by jsolerBtis » Tue Jan 29, 2019 11:07 am
I tried doing it manually with "Bitmap Export" in QCAD using the same parameters and when i uncheck this: "add extra margin to compensate for line weight", the TIFF files fits well.
(And obviously, with this check i have the same problem).
Post by andrew » Tue Jan 29, 2019 1:49 pm
Strange.. QCAD uses the same routines and parameters.
Perhaps you could create a bitmap with double or four times the required resolution and then scale it down accordingly (e.g. using imagemagick command line tools). Switching on antialiasing in QCAD might also have a similar effect (properties["antialiasing"] = true).
jsolerBtis
Post by jsolerBtis » Tue Jan 29, 2019 2:58 pm
And which is the propertie to change this "extra margin"? I mean, something like: "properties["ExtraMargin"] = false "
i can't create bitmaps with high resolution cause we're doing an automatic procedure that generates tiles like every hour.
Post by andrew » Tue Jan 29, 2019 9:11 pm
That switch for adding line weight margin is reflected in the bitmap exporter through parameter "noweightmargin":
properties["noweightmargin"] = true;
jsolerBtis
Post by jsolerBtis » Wed Jan 30, 2019 9:28 am
This solves my problem.
Thanks Andrew!
Return to “Chat”
