How do I get the inch symbol (") to appear behind the dimensions in my drawing?
I'm using windows 10
Qcad version 3.21.3.0 (3.21.3)
Inch symbol in dimensions
- Inch symbol.JPG (16.47 KiB) Viewed 5738 times
Re: Inch symbol in dimensions
After selecting a dimension you can edit specific properties in the Property Editor.
When you change the Label from Auto to <>" you will get the desired result.
The <> is a placeholder and it will be replaced by the value of the measured dimension (in this example by 60,37)
Before and after the placeholder you can place any text you want.
Thomas
Thomas
