Snap
Graham Wright
Snap
Post by Graham Wright » Wed Sep 26, 2018 11:09 am
I am recommended to snap to grid in the foreword. After a few drawings, I find this generally very helpful. However, I seem to run into problem with setting the grid. I understand there are two lots of preferences and have been using the edit one. I seem to be stuck with a 1mm grid even though requesting 0.1 etc. I have set the minimum grid lower in main preferences.
Which finger am I having problems with? :?
Re: Snap
Post by andrew » Wed Sep 26, 2018 11:13 am
Please attach your drawing file (it contains all the settings that could be off).
Graham Wright
Re: Snap
Post by Graham Wright » Wed Sep 26, 2018 11:21 am
Please point me to it. (I am a novice!)
Re: Snap
Post by andrew » Wed Sep 26, 2018 11:24 am
If you need help with attaching files to a forum post, please refer to:
viewtopic.php?f=47&t=3760
Graham Wright
Re: Snap
Post by Graham Wright » Wed Sep 26, 2018 11:33 am
Please confirm receipt.
Graham Wright
Re: Snap
Post by Graham Wright » Wed Sep 26, 2018 11:34 am
Boat Electrical System pdf.pdf
(209.63 KiB) Downloaded 718 times
Re: Snap
Post by Husky » Wed Sep 26, 2018 6:40 pm
Thanks for the pdf but we need the dxf or dwg to look into it. Please attach the dxf / dwg to this post.
Return to “Chat”
