Andrew,
Still version 3.21.1.0 ; Win7 32bit.
In QCAD we can draw splines by fit-points and control-points.
An example of those are in the example included.
On investigation the spline in the post of benjamindahl is a different kind:
https://www.qcad.org/rsforum/viewtopic. ... 859#p21518
Stepping through the points:
-fit-points: steps from fit-point to fit-point. Start- and end-point and fitpoints are knots on the curve.
-control-points: steps from start-point over control-points (not necessarily on the curve) to end-point.
The knot points can be found on the curve as 'intersections'.
-benjamindahl: from the start-point every thirth control is a knot-point.
Knot-points are on the curve and also found as 'intersections'.
Two references in between two knots are vectors and not necessarily on the curve.
It seems this is more like a string of bezier segments.
What is the difference? How are they named?
Can the third kind (knot-vector-vector-knot-....) be constructed with QCAD?
Regards
Different kinds of splines.
- Text Explode Spline 2 linesegments.dxf
- (157.15 KiB) Downloaded 521 times
Re: Different kinds of splines.
So the third kind is suported if originated from 3d party?
Knot vectors are imported as they are stored in DXF but cannot be changed in QCAD.
