Explode spline to polyline with line segments
Post by CVH » Sat Aug 25, 2018 9:20 am
Andrew,
Still version 3.21.1.0 ; Win7 32bit.
Is there a reason why exploding splines to polylines with line segments yields 4 times the number of nodes per segment set in App Prefs.
Example included.
reading http://www.qcad.org/bugtracker/index.ph ... sk_id=1479
This should be 2 in version 3.15.5.
Nowdays it is configurable.
Regards
Text Explode Spline 2 linesegments.dxf
(157.15 KiB) Downloaded 506 times
Re: Explode spline to polyline with line segments
Post by andrew » Mon Aug 27, 2018 11:57 am
N segments are created per control point. This is to make sure composite splines are exploded with the same resolution as simpler splines.
Post by CVH » Mon Aug 27, 2018 12:40 pm
[quote=andrew post_id=21574 time=1535367473 user_id=2]
N segments are created per control point. [/quote]
Fitpoint spline has 10 fit points and 14 knot vectors.
Control spline has 12 control points and 14 knot vectors.
Both splines are qubic and have 9 segments.
Yields:
N=2 => 73 vertexes = 9 x 8 +1 nodes
N=4 => 145 vertexes = 9 x 16 +1 nodes
N=8 => 289 vertexes = 9 x 32 +1 nodes
that is 4 times N times #segments plus one.
Return to “Chat”
