import
- Active Member
import
When I try to import an item, I choose the layer I want to import to but...QCAD has other ideas. strange thing is another import went right on the layer of my desire as you see in the picture. So is this something to do with the import item?
- Screen Shot 2016-10-16 at 2.06.03 PM.png (265.17 KiB) Viewed 6339 times
Re: import
Hi Mr Confused,
have you told QCAD what to do with the import?Mr Confused wrote:When I try to import an item, I choose the layer I want to import to but...QCAD has other ideas.
