Thread chasing dial
Thread chasing dial
This one is for Husky: here's the unit I built with your help on the gear design, works nicely. The hardest part was achieving a decent shape for the bit I used to cut the gears...
- gear cutting...
- taille de pignon-sm.jpg (81.16 KiB) Viewed 10957 times
- Thread chasing dial, built from scratch.
- appareil à retomber dans le pas-sm.jpg (98.53 KiB) Viewed 10957 times
Re: Thread chasing dial
That looks really nice!!!
Thank you for the update on your project! What's next?
Maybe another hybrid boat transmission?
How many "Helios" do you need?J-J wrote:Maybe another hybrid boat transmission?
By the way - is the Helios for Lake and River usage or also able to handle the open sea?
Helios is used on the Med in Marseille. It is not currently used far out at sea, but it does take heavy seas quite well.
Thanks for the Info
