annoying hatch pattern covering pointer position
Andrepr
Post by Andrepr » Mon Jan 15, 2024 8:56 pm
Just downloaded Version 3.29.0
Using Win 11
Now have annoying partially obscuring floating hatch pattern covering pointer position. e_confused
Thanks for previous problem solution regarding rulers.
André (Montreal, Canada)
hatch pattern.jpg (2.82 MiB) Viewed 1398 times
Re: annoying hatch pattern covering pointer position
Post by CVH » Tue Jan 16, 2024 7:30 am
I hope this isn't your cursor being malformed.
Are you using system cursors or not?
See menu Edit .. Application Preferences .. Graphics View .. Appearance .. Cursor
You can always try to reset your configuration:
Remind that this will reset all your QCAD customization's and tool options.
I can not find references about your previous problem, this is your first posting under user 'Andrepr'.
Andrepr
Post by Andrepr » Tue Jan 16, 2024 7:19 pm
Win 11
Ver 3.29.0
Wasn't using system cursors... Changed and seems fine now.
Thanks for yo :) ur help.
André
Post by CVH » Wed Jan 17, 2024 8:20 am
This should not be an issue.
It is more a general preference in the nature of "I like to use my system cursors"
Something has changed recently:
https://github.com/qcad/qcad/commit/614 ... 50054d450d
Maybe reporting it as a bug on Bugtracker is in order.
Filed a report: https://qcad.org/bugtracker/index.php?d ... sk_id=2517
Return to “Chat”
