WildWolfCJ wrote: ↑Thu Nov 02, 2023 7:05 am
I just tested the -enable-script-debugger parameter, but no debugger interface appears?
The debugger would pop up when there is an error or at the point in the code where you included
debugger;
But as said: Never tried it in command line mode.
For some reason the UAC does not allow me to address QCAD or one of the folders from the OS command line.
Lets go back to:
WildWolfCJ wrote: ↑Wed Nov 01, 2023 9:09 am
I have successfully implemented this function according to your instructions. Thank you very much for your help.
One could halt that script before printing.
debugger; // Halt script before printing the string when QCAD is started with -enable-script-debugger
// Export the composed string:
print(texStr);
