Hello everyone. I created this thread because I've just started using QCAD for the first time and was wondering about some things. Thank you in advance for the replies. My questions:
1) What is the purpose of the little red crosshairs? If I draw a line from point A to point B, after I'm done drawing the line, there will be a tiny red crosshairs at point B that stays there until I draw something else. Is there a purpose to this and/or is there any way I can disable it?
2) When typing a command into the command line, I first have to click on the command line to select it. Is there any way to make it so when I type a command (e.g., mv for move) it just automatically knows that (unless I'm editing text or something) I want it to go to the command line? If I'm typing mv and I have nothing else selected, it's obvious that that's supposed to go to the command line rather than nowhere.
3) The linetypes drawn within a block don't seem to pass through to the model. For example, if I draw a line within its own block and I make that line layer 0 and select "by layer" for the lineweight, when I use that block within the model space and put it on a layer, it only changes color to match the layer but the linetype (e.g., hidden should be dashed) doesn't come through and it is shown as solid. Am I doing it wrong and/or is there a way to transfer linetypes through from blocks?
4) The lineweight property doesn't seem to make lines thicker and instead only changes the linetype scale. Is that right? Shouldn't selecting a thicker lineweight make the line itself thicker/fatter?
5) I was looking into maybe making my own custom tools and was wondering what's the difference between plugins and scripts, if any? Say I code a custom tool that makes some fancy drawing or something, do I put the javascript file in the scripts folder or the plugins folder?
I think that's it. See attached file to demonstrate what I'm seeing regarding the lineweight and linetype questions. Again, thanks in advance for your time reading this and/or replying.
Some Questions
- Junior Member
Some Questions
- Sample.dxf
- (168.24 KiB) Downloaded 260 times
Re: Some Questions
That is the relative position ... The origin when using Relative or Relative Polar coordinates.333onlyhalfevil wrote: ↑Fri Apr 28, 2023 1:08 pm1) What is the purpose of the little red crosshairs?
Usually the last position you used as coordinate in this instance of QCAD and this drawing.
The Space-bar is the shortcut to set the focus on the Command Line.333onlyhalfevil wrote: ↑Fri Apr 28, 2023 1:08 pm2) When typing a command into the command line, I first have to click on the command line to select it.
You can type the 2 letter key tool shortcut almost everywhere at any time.
Indeed except when editing text.
All depends what display mode your are in.333onlyhalfevil wrote: ↑Fri Apr 28, 2023 1:08 pm4) The lineweight property doesn't seem to make lines thicker and instead only changes the linetype scale. Is that right?
Remark that Screen-based Linetypes is a hybrid.
It will display all somewhat thin/thick and somewhat dashed/dotted in any zoom state.
A line 1mm wide would fill the screen not using Screen-based and zoomed in very close.
But a 1mm wide line would always print as 1mm wide regardless the paper scale.
These sizes are from back in the days we drew with real pens, with ink on chalk paper.
And all depends on Application Preferences and Drawing Preferences.
Linetype may be related to weight, see: Graphics View .. Appearance .. Scale linetype patterns by line weight.
An addon in the script folder. A plugin is for example the QCAD Pro package, QCAD/CAM.333onlyhalfevil wrote: ↑Fri Apr 28, 2023 1:08 pm5) ... Say I code a custom tool that makes some fancy drawing or something, do I put the javascript file in the scripts folder or the plugins folder?
Remark that there is a relation between the folder structure and the menu structure.
Scripts that you run with XC may be located anywhere, keep those in your personal custom folders.
3) It is all just a mind twist but there are unanswered things too.
Block 'Wall'; 12 lines on layer 0 = White; Color is byBlock; The Block Reference is on Layer 'Wood Walls' = Custom (#cb9866); Color is byLayer
In Model_Space they display in the 'Wood Walls' color (over here).
Now edit Block 'Wall', they are white by the layer.
What color would 'byBlock' be in block edit mode? Where do we set that?
But there are other differences down the line.
Layer 0 may be set as a regular QCAD layer or different ... Best compatibility.
Re: Some Questions
Hi 333onlyhalfevil - welcome to the QCAD comunity.
BTW - I like your nickname. Tells me everything what I need to know ... LOL
Set it to "Layer 0 behaves differently (best compatibility). Entities in blocks on layer 0 take on attributes and visibility of block reference" and you will get what you are looking for.
Your QCAD preference for layer compatibility is set to "Layer 0 behaves like a regular layer (QCAD)".333onlyhalfevil wrote: ↑Fri Apr 28, 2023 1:08 pm3) The linetypes drawn within a block don't seem to pass through to the model. For example, if I draw a line within its own block and I make that line layer 0 and select "by layer" for the lineweight, when I use that block within the model space and put it on a layer, it only changes color to match the layer but the linetype (e.g., hidden should be dashed) doesn't come through and it is shown as solid. Am I doing it wrong and/or is there a way to transfer linetypes through from blocks?
- Junior Member
Re: Some Questions
Hmm, I thought I replied to this already. My bad. Thank you both very much for your time/replies. They were very helpful in helping me make that first step from autocad to qcad.
