[sovled] Objects being moved to different layers and changing colour when moving
lesthegringo
Post by lesthegringo » Wed Jan 25, 2023 10:42 am
Hi all, this has only been happening for the last day or so, but whenever I move, copy or modify any line or selection, it automatically sets it to the 0 layer and the 0 layer colour
I wanted to put in the bug list as per the initial instructions but there is nowhere to click for 'add new bug'
I have updated QCad (today) and it still happens with the latest version
Cheers
Les
Re: Objects being moved to different layers and changing colour when moving
Post by andrew » Wed Jan 25, 2023 10:49 am
When moving, be sure that the option "Use current layer and attributes" in the dialog is not checked.
See also:
https://qcad.org/doc/qcad/latest/refere ... /Translate
The new entities are placed on the same layer as the originals and have the same attributes. To use the current layer and current attributes instead, tick "Use current layer and attributes".
lesthegringo
Post by lesthegringo » Fri Jan 27, 2023 4:51 am
Thanks, that is what I apparently had done - I must have checked it by mistake
Cheers
Les
