Post
by Husky » Thu Dec 30, 2021 11:50 pm
yeti01 wrote: ↑Thu Dec 30, 2021 12:55 pm
How can I change the color/attributes of such symbols (w/o changing the symbol itself)?
Use different layer within the block,
or
use custom colors for single entities in your block,
or
explode the block after inserting it,
or
switch your Layer Compatibility to "Layer 0 behaves like a regular Iayer (QCAD)",
etc. etc. etc.
This example circle is one block inserted on different layer. You may play with it to see what you can do to control the attributes in a block.
- Husky-2021.12.30-05.png (16.71 KiB) Viewed 5133 times
