How to add nodes?
Kylerg3077
How to add nodes?
Post by Kylerg3077 » Wed Dec 01, 2021 3:37 am
How do you add nodes with the free version of QCAD? Or is it not necessary to have more than more nodes on a circle when you are going to have it cnc plasma cut? Thanks
Re: How to add nodes?
Post by CVH » Wed Dec 01, 2021 5:17 am
you posted this on the "QCAD Professional" forum.
Please use the "QCAD Community Edition" when you use the free CE version.
... more nodes on a circle
The so called nodes when you select a circle entity are called reference points that can be used for snapping.
4 little squares on the exterior and a round one at the center point.
... when you are going to have it cnc plasma cut?
Depends mostly on the CNC hardware.
Many support circles or full arcs, most 2 semi circles, some require 1/4 circular arcs.
Only when G2/G3 is not supported, it is necessary to interpolate arcs/circles with line segments.
In fact, it is the CAM side that has to deal with that.
From the CAD perspective, circles are fine as they are. :wink:
Kylerg3077
Post by Kylerg3077 » Wed Dec 01, 2021 10:13 pm
Sorry I posted in the wrong spot. But thanks for your help!!
