[solved] Empty of drawing
xogus12
Post by xogus12 » Thu Jul 15, 2021 7:21 am
Hello
I finished the drawing with QCAD professional. 3.26.20
When I opened the drawing on QCAD, there is nothing.
But it's no problem to see it via Autodesk dwg viewer
Would you please advise me how can I open it on QCAD?
11111.dxf
(138.04 KiB) Downloaded 329 times
Re: Empty of drawing
Post by CVH » Thu Jul 15, 2021 7:57 am
You posted in the free Community Edition.
As PRO user one would post in the PRO forums.
On layer 'Font' there is a line entity with handle =0x40a that is 11111111 units long.
On open, QCAD will auto zoom by default. :wink:
Only found 2 layers with entities on them.
Post by Husky » Thu Jul 15, 2021 8:30 am
Launch Qcad,
load the drawing,
after loading it will show a long horizontal white line (mentioned already by CVH),
select the line and delete it,
use then auto zoom to focus on the drawing - you will find the command below Menu / View / Zoom
xogus12
Post by xogus12 » Thu Jul 15, 2021 9:43 am
Dear Husky and CVH
Thank you so much quick solution.
I didn't think about the long line.
