Hi
How to easily find polygon area ?
It is always difficult to manually trace polygonal sides to find area .
is there any way same as hatch AREA in other CAD software?
How to easily find polygonal area?
- aaa.dxf
- (108.03 KiB) Downloaded 357 times
- polygon.png (13.52 KiB) Viewed 5887 times
Re: How to easily find polygonal area?
You can use the tool "Polyline from Segments" (OG) to convert your shape built out of lines to a polyline. Then select the shape and check the Property Editor for the Area size ...
But you must using trial or purchased version not free one
Also you have to remove or any points layer before select polyline to get area in property editor
Well, because you posted your question in the QCAD Professional forum and my answer refers (of course) to the QCAD Pro tools.
No.
Topic moved to QCAD CE!
