[solved] When I paste object is rotated 90 degrees
RogerRamjet
Post by RogerRamjet » Tue Jun 15, 2021 5:20 pm
Newbie here...
When I copy an existing entity and then paste it, the entity is rotated 90 degrees and I don't know why.
I'm copying things from my drawing (call it Mine) into another drawing that came from someone else (call it Theirs).
When I paste the entity from Mine into Theirs, it is rotated 90 degrees.
Questions:
1. What am I doing wrong?
2. How do I fix it?
3. Where is a good tutorial that explains things that should be initialized when creating a new drawing?
Running QCAD ver 3.24.3 on Win10 Pro.
Drawing is a .dxf
TIA
Re: When I paste object is rotated 90 degrees
Post by CVH » Tue Jun 15, 2021 5:37 pm
Have a look at your Options Toolbar:
Most methods initiate an Options Toolbar, so allways keep an eye open for those options. :wink:
RogerRamjet
Post by RogerRamjet » Tue Jun 15, 2021 7:06 pm
Thank you CVH..
That was embarrassingly simple ;)
