Aligned text or table
massimo
Post by massimo » Mon Nov 02, 2020 3:17 pm
Hi, I try to write a text block with tabulator aligned text or something like a table.
Adding a tabulator adds some " " in the Rich text (Simple text disabled), it is some spacing but not aligned from one line to the other. How can I do that?
The only workaround I found is using appropriate spaces, and this requires using a fixed width font of course which does look as nice as the default font used for dimensions.
Community Version 3.28.2.0, Gentoo Linux on amd64
Re: Aligned text or table
Post by Husky » Tue Nov 03, 2020 12:24 am
You'll not like what I tell you ... e_surprised
QCAD in the current version doesn't support fancy text formatting.
A workaround for small tables could be:
Work with columns and align them left / right / center. On that way you can built a table with proper aligned text.
In this example I used for the first column aligned to the left, for the second column aligned to the right.
Will that make sense for big tables .................... nope. :(
Sure - you can also work with a Monospace text font but that looks most of the time like somebody found and used a historic typewriter ...
massimo
Post by massimo » Tue Nov 03, 2020 11:19 am
Please add support for the historical tabulator or horizontal tabulation (HT) or character tabulation, which in ASCII has the decimal character code of 9, before adding support for fancy text formatting :)
Thanks.
