1) Is there a Gerber plugin for Qcad or is there anyone here who know of a stand-alone dxf to gerber converter that runs on Linux. ?
2) Autocad has a Gerber plugin and you can create gerber files from DXF.
Is there any way that Autocad plugins work on Qcad,
QCAD and Gerber
- Junior Member
Re: QCAD and Gerber
There is virtually no chance that an AutoCAD plugin will work with QCAD - why would it?
For Gerber files you might want to look at using KiCAD
https://www.kicad.org/help/file-formats/
